Cyton SPI SCLK frequency
I'm trying to understand what is the SPI data rate between the PIC32 and the ADS1299 in the Cyton board. I know that the sample rate is 250SPS, but I would like to know what is the bit rate that one sample is transmited in the SPI bus. Can someone help me?
Thanks.
Hi GEng,
Some related discussion here,
http://chipkit.net/forum/viewtopic.php?t=243
http://ww1.microchip.com/downloads/en/DeviceDoc/DS-61106F.pdf
https://microchipdeveloper.com/32bit:mx-osc-config
SCLK is ONE bit time on the SPI bus.
GEng, hi again.
OK, final post.
Thanks to Eva Esteban @evaesteban, here is the actual line in the source code,
https://github.com/OpenBCI/OpenBCI_Cyton_Library/blob/master/OpenBCI_32bit_Library.cpp#L1326
So SCLK is 4 MHz. Also, the external crystal / resonator is 8 MHz, so a divide by two factor is common to derive SCLK.
