Brainflow AttributeError's
I’m trying to get connected to my Cyton via BrainFlow from the command line. I’ve been following the code samples however when I try to run the basic example I get the following:
File "/Library/Frameworks/Python.framework/Versions/3.8/lib/python3.8/site-packages/brainflow/board_shim.py", line 387, in init
self.input_json = input_params.to_json ().encode ()
AttributeError: 'str' object has no attribute 'to_json'
During handling of the above exception, another exception occurred:
File "/Users/Tyler/Documents/GetData.py", line 45, in
main ()
File "/Users/Tyler/Documents/GetData.py", line 22, in main
board = brainflow.board_shim.BoardShim (0, '/dev/tty.usbserial-3')
File "/Library/Frameworks/Python.framework/Versions/3.8/lib/python3.8/site-packages/brainflow/board_shim.py", line 389, in init
Programming is not my strong suit, so any help would be appreciated.
Mentioning Andrey Parfenov @Andrey1994.
In BrainFlow 1.x this
was correct. Now latest version is 3.4.0 and this API was changed a little. Check docs and code samples for details
Andrey, thanks!
Tyler, you can also join the Brainflow Slack at,
https://brainflow.ai/2020-03-23-slack/
