8 bit or 32 bit board?
Hi all,
As an ex Emotiv Epoc owner, I'm really excited to see this device as it seems that I can finally get my hands on some useful data.
I'm interested in purchasing one of your 8 channel boards to start with (and a daisy chain board later) but I'm unsure as to the pros and cons of each board. Forgive me if I'm being dense but can you please provide me with an explanation?
Thanks in advance!
Leigh
Checkout the previous posts on this thread.
The 32 bit version is 'compatible' with Arduino code, but not exactly the same. So there may be some adjustment needed for example if you are importing an Arduino library to run under Chipkit.
http://chipkit.net/tips-porting-arduino-libraries/
Also there is a 'Search" box at the lower right of the forum pages. For example searching for 'chipkit' would have uncovered this thread.
See some of the links on the thread below. If you have a medical rated power supply and isolation on the interface, you're fine. However, many Makers would be inclined to take shortcuts. Which would expose OpenBCI to legal liabilities.
http://openbci.com/forum/index.php?p=/discussion/243/spi-wifi-transfer-eeg-data-to-external-device
https://www.google.com/search?q=medical+power+supply+leakage
