recommended equipment for ERP
Sertan
İstanbul
Greetings,
Here is the concept of my experiment: I will show some flying dart pictures to subject and collect the EEG data and try to determine which dart picture end up with the bullseye shot.
- Which equipment do you suggest for this kind of research?
- How many channels do i need?
- I understand that i need to monitor the eyes and blinkings and pulse. what is the proper equipment for this task?
Sertan, hi.
The "Google Advanced Search" button in upper right column, can be used to search for relevant terms, for example:
https://www.google.com/search?as_q=p300&as_sitesearch=openbci.com
You could use either Ganglion or Cyton for P300 work. Depending on how many channels you want, if you need to work with external triggers, etc. Cyton has 8 channels, plus three additional 'Aux' channels that can be used to record external trigger events. Ganglion has only 4 channels.
See this related post regarding de-artifacting.
https://openbci.com/forum/index.php?p=/discussion/1258/artifact-detection-thresholds-algorithms
