DIY Cyton: "exec: '/bin/pic32-g++': file does not exist" [resolved]
DreambuildDreambuild China
edited April 2020 in Build-it-yourself
Hello there, guys. I was recently trying to prepare to program my diy Cyton board, but I have met problems in compiling. Here's a screen shot.
//Arduino: 1.8.7 (Windows 10), Board: "OpenBCI 32"
exec: "/bin/pic32-g++": file does not exist
This report would have more information with
"Show verbose output during compilation"
option enabled in File -> Preferences.//
Here's what it said.
Chipkit core and other files have been installed. pic32-g++ also do exists in bin file, but the system still can not find it.
Can anyone help me on this one?
  • DreambuildDreambuild China
    edited April 2020
    Guys, I just found the solution to it, which 's pretty simple. It could be helpful if someone met the same problem.
    I open the platform.txt and got into here
    Default "compiler.path" is correct, change only if you want to override the initial value
    This line must be set right ({runtime.tools.pic32-tools.path}/bin/) for the ZIP file builds. It gets replaced
    by build.xml regex to {runtime.tools.pic32-tools.path}/bin/ for the URL (github-release) build
    compiler.path={runtime.tools.pic32-tools.path}/bin/
    Now change the compiler.path={runtime.tools.pic32-tools.path}/bin/
    to the actual location. Mine for example:
    compiler.path=D:/System/Arduino/hardware/chipkit-core/pic32/compiler/pic32-tools/bin/
    Remember to use / instead of \ to show the path.
  • Hi, Dreambuild
    I followed the steps you mentioned: open the platform.txt and change the compiler.path={runtime.tools.pic32-tools.path}/bin/
    to the actual location. Mine :E:/ApplicationSoftware/Arduino/Arduino1.8.0/Arduino/hardware/chipkit-core/pic32/compiler/pic32-tools/bin/
    now, it can compile successfully, but it cannot upload DefaultBoard.ino successfully, some errors occured like this:
    could you please give me some suggestions?
    Best Regards
  • @Dreambuild Look forward to your reply! Thanks in advance.
