Daisy Module / "Init timeout" - standalone app vs Processing
I am using the OpenBCI 16-channel R&D kit with the stand-alone Mac OSX OpenBCI GUI to test the system as the first step in using the EEG. When I connect the board without the Daisy Module connected, the connection works just fine; however, when I add the Daisy Module to the standard board and start the GUI with the 16-channel button selected, I get "Init timeout. Verify your Serial/COM Port Power Up/Down your OpenBCI & USB Dongle The retry initialization". I've tried doing this but I still have not gotten it to work. I've also tested the connections on the Daisy Module and OpenBCI board that I had to solder. Have any of you who are using the 16-channel R&D kit gotten this error and how would I fix this problem? Thanks!
