delay in stream data from OpenBCI_GUI to Matlab 2019
I am using the Cyton board and the dongle to receive data from 8 channels in a Windows PC. I am able to visualize all the 8 signals in real time on the OpenBCI_GUI. However, when I set up the LSL from this GUI to stream data into Matlab, I have noticed that the stream data in Matlab has a long delay of approximately 20 to 23 seconds. In Matlab, from the command window I use: vis_stream. This allows me to visualize the 8 signals with the long delay of 20 s. I tried changing different parameters (from the vis_stream pop up window) such as maximum time range to buffer, sampling rate for display and refresh rate for display but the long delay of over 20 s in the stream data persisted.
I also tried creating different Matlab scripts where I use pull_sample() or pull_sample(0) or pull_chunk() functions and plot the stream data but obtain the same long delays in the stream data.
Any advice will be greatly appreciate it.
Fredy
    edited August 2019
    @FredyMunoz
    I am the developer who fixed LSL output from the GUI. Before, it was completely broken. The output from the GUI using LSL is very strait forward, with little room for error. I have successfully tested LSL networking using OpenVibe ONLY with no delays or issues of any kind!
    Please provide an example Matlab sketch/program so that myself and others can test this and replicate/resolve any issues with GUI->MATLAB integration.
    ALL MATLAB USERS: Are there any obvious errors in the OpenBCI MATLAB Doc???
    If so, please make an issue here on the new Docs repo.
  • edited February 2020
    Please see below the script that I use with the pull.sample() function. I put side by side the real-time signals displayed on the OpenBCI_GUI and the figure plotted in the Matlab script. I notice a delay greater than 20 s in the signals displayed by the Matlab script.
    Thanks for your help.
    disp('Loading the library...');
    lib = lsl_loadlib();
    disp('Resolving an EEG stream...');
    result = {};
    while isempty(result)
        result = lsl_resolve_byprop(lib,'type','EEG'); end
    disp('Opening an inlet...');
    inlet = lsl_inlet(result{1});
    disp('Now receiving data...');
    fs=250;%Hz
    duration=1;%seconds
    totalSamples=duration*fs;
    displayTime=10;%in seconds
    EMGdata=zeros(totalSamples,8);
    timeStamp=zeros(totalSamples,1);
    displayRawSignals=zeros(displayTime*fs,8);
    stop=0;
    counter=0;
    while 1
       [vec,ts] = inlet.pull_sample();
       if isempty(vec)~=1
         counter=counter+1;
         if counter<=totalSamples
            EMGdata(counter,1:8)=vec;
            timeStamp(counter,1)=ts;
         else
            counter=0;
            stop=1;
         end
       end
        if stop==1%
            displayRawSignals=circshift(displayRawSignals,-totalSamples);
            displayRawSignals(displayTime*fs-totalSamples+1:displayTime*fs,:)=EMGdata;
            figure (1)
            plot(displayRawSignals(:,1),'r')
            stop=0;
         end
    end
    Moving this to an OpenBCI GUI Issue: https://github.com/OpenBCI/OpenBCI_GUI/issues/595
    Looks like LSL streaming needs a handful of work, and there is a need to prioritize LSL streaming for the next GUI releases.
  • Hey there,
    I replicated the 23seconds delay issue from GUI -> MATLAB using my own MATLAB scripts.
    Is there currently any known configuration where live streaming from Cyton to MATLAB works? Maybe Python --> MATLAB?
    edited October 2019
    Everyone please try 4.1.6. There was a bug that didn't allow multiple LSL streams to work properly, and it has been fixed.
    I've written some simple LSL python scripts: https://github.com/OpenBCI/OpenBCI_GUI/tree/master/Networking-Test-Kit/LSL. This allowed me to debug the issue.
    Also, I am running Matlab2019b with liblsl-Matlab-1.10 added to my Matlab Path, and I do not see a delay!
    edited October 2019
    All of these people experiencing a delay have to have something in common... Not quite sure what it is.
    Please refer to the above screenshot. I was not able to replicate any type of delay using: Matlab, OpenVibe, or Python.
    @FredyMunoz Are you using 32bit or 64bit apps? GUI and Matlab?
  • Hey,
    Testing the OpenBCI GUI to stream over LSL from the Cython board, and I was able to replicated the 23 s delay.
    My system is W10 64-bits, and the OpenBCI GUI is 4.1.7, and the LSL stream was read from Python3 using pylsl.
    Later, I used OpenBCI_LSL to stream data from the Cython board over LSL. And using the same Python3 codes to received data, and there was not noticeable delay.
