Steaming via Node.js [resolved]
Hi, I'm new to OpenBCI board and I'm trying to use Node.js to live-stream data for a model to real-time categorize EMG data. When I use GUI, the graph looks very distinguishable that where the muscle is used and where it's not. But when I stream to node, all I got for each channel is a number that doesn't change much, and couldn't produce meaningful output. Did I miss some data processing steps? Should I stream the data directly from the board or via the GUI networking? Are there difference? Thank you so much!
John, hi.
Are you interpreting the "number that doesn't change much", correctly? I thought the JS libraries are presenting values in Volts, vs Microvolts. So for example 20 microvolts would look like: .000020, a typical EEG value. Then 200 microvolts (more typical for EMG) would look like .000200. So these all look very small at first glance.
Also with Cyton, there is a "DC offset" that is present on top of the incoming signal. This must be filtered off with a DSP digital signal processing filter. I'm sure Javascript has various DSP libraries available. A typical thing to do is either a high pass at say .5 Hz, or a bandpass from .5 Hz to say 45 Hz. (for EEG). For EMG you may want to go higher, say up to 100 Hz. Also the GUI uses both a bandpass and a notch filter at mains frequency. DC offset values are typically in the range of a few tens of millivolts. For example 10 millivolts in volts is: .010000. So since all your values are going to have a millivolt offset this slowly changing DC offset will be added to all the values you see.
https://www.google.com/search?q=javascript+dsp+library
Thank you so much for your help! This is really helpful!
Best, John
