OpenViBE P300 Speller won't type in any mode
I followed Jeremy's blog step by step, I got accuracy of 84.38% but when I changed it from Calibration to Copy Mode, It won't write anything. The same happened in Fr (Free mode)
Where did I go wrong ?
Everything's is same the os version is ubuntu 14.04
OpenVibe version is 0.18
Any help would be appreciated
Thanks
Ayushmh, hi. I believe if you look through some of the past threads related to the OpenViBE P300 Speller -- I think the statement you will find is that the Speller is no longer supported on current versions of OpenViBE. I've posted in the past on the OpenViBE discussion forum. Asking if there are plans to update the Speller code. You could check and ask there similarly.
http://openvibe.inria.fr/forum/search.php?keywords=speller&submit=Search
I see from your post above that you tried with an older version of OpenViBE, but that is likely a mixed bag. You are missing many of the bug fixes in more recent versions.
I do believe the OpenViBE team would welcome any open source developers helping to upgrade the speller to be again compatible.
http://openbci.com/forum/index.php?p=/discussion/206/openvibe-p300-speller-tutorial-questions#latest
http://openvibe.inria.fr/forum/viewtopic.php?f=17&t=9613
