"board unresponsive": resolved
edited January 2015 in Cyton
I am currently attempting to follow the getting started guide
http://docs.openbci.com/tutorials/01-GettingStarted
I have got processing installed
Repo is downloaded
I am able to edit the start-up variables ie
final int eegDataSource = DATASOURCE_NORMAL;
I start the software through processing and then swipe my fingers across the pins as described in the guide and i get no reaction from the GUI.
To clarify the board is on (blue light)
The USB dongle is on and set to correct mode
The code points to com4 which i have identified my dongle to be on.
If I set the data source to playback it works.
Any help would be appreciated in resolving this issue.
  • Here is the output from Processing
    Starting setup...
    COM1 COM4
    OpenBCI_GUI: Opening Serial COM4
    OpenBCI_ADS1299: setBiasAutoState: setting bias to AUTO
    openBCI: openNewLogFile: opened output file: SavedData\openBCI_raw_2015-01-01_15-30-36.txt
    OpenBCI_ADS1299: startDataTransfer: using current dataMode...
    OpenBCI_ADS1299: startDataTransfer: cannot start transfer...waiting for comms...
    setup: Setup complete...
    OpenBCI_ADS1299: startDataTransfer: received command for mode = 1
    OpenBCI_ADS1299: startDataTransfer: starting binary transfer
  • Getting latest resolved my problem.
