DefaultWifiShield.bin works, but DefaultWifiShield.ino doesn't
I have been trying to build the wifi code from the source, I have followed the instructions provided on the OpenBCI website. However, when I build everything using Arduino IDE the wifi shield does not work properly using the GUI (i.e. everything is fine (I can see the firmware version, the board name, MAC address etc.) until I press the "start session" button and then nothing happens.... I have tried all the different options available in the GUI(TCP,UDP, 250hz,1000hz etc.), but the same result). However, when I use the prebuilt binary, it works fine. This makes me wonder, is the binary file provided on the git repository the complied version of the DefaultWifiShield.ino file or is it a different source code?
I am using the latest Arduino IDE, windows 10 x64 and the files for firmware 2.0.5.
p.s. I noticed that when I compile using Arduino IDE, the OpenBCI GUI reports the firmware version as 2.0.3 even-though I have used the source codes for version 2.0.5.
Also, I was wondering, what version of ArduinoJson is used to compile the binary version available at the git repository?
khash
