Cyton Recording withoud PC and Dongle
Is it possible to disconnect the connection between dongle and Cyton when saving to SD card and reconnect it later? I would like to record my sleep without a PC.
  • One of the nice things about writing the data in blocks is that once the block is written, it is on the card. In other words, if you create a file that allocates 30 minutes of record time and then stop your recording after only 15 minutes (by resetting the uC, or powering down the board, or pulling out the card) all of the data that was written will still be on the card!>
    so it should work.
