Unable link OpenBCI-Hub Kubuntu 19.04 (OpenBCI GUI as a "Standalone" Application)
in OpenBCI_GUI
Can't get Cyton to run under Kubuntu 19.04. The FTTDI driver should be included in the kernel and the permissions for the serial port I also considered. I get the message Unable link OpenBCI-Hub. Even if you copy the individual hub application to the Data folder, there is no success.
In such a case, the Hub is not even running. You need to find a way to make it run. Try using
sudo.Sudo doesn't work either. I tried npm now but got a lot of bugs. I need to take another look at this in peace.
@openoli73 I don't the GUI has been tested on 19.04.
https://github.com/OpenBCI/OpenBCI_Hub/releases/tag/v2.1.0
Try to run that. Just by itself.
https://github.com/electron/electron/issues/1518
app is ready
is working, many thanks
@openoli The GUI is supposed launch the Hub automatically:
Is the GUI able to start the Hub? Or do you have to do it manually? Have you tried replacing the Hub in the data folder with the one you got to run?
Just curious because you are running Kubuntu 19.04. Thanks!
I didn't replace the folder and after installing the package, I started the GUI. So the hub was started automatically. Everything runs fine.
