can we connect two cytons to one computer and read their EEG simultaneously?
edited August 2019 in Cyton
can we connect two Cytons to one computer and read their EEGs simultaneously via bluetooth dongles (250hz)?
If we can, would a Macbook Pro 2015 (2.7 GHz Intel Core i5, 16GB RAM, SSD HD) be able to do FFT on both signals efficiently and leave me enough 'power' to synthesise/trigger sounds? I guess, I might just have to try this part.
Many thanks, k
    Kris, hi.
    Yes, if the Cyton's are using two different radio channels (two separate usb serial ports). I'm not sure you can run two GUI instances, but if you are using some other interface that handles two serial ports simultaneously, that should be fine. Your Macbook should have enough processing power.
    Great, thanks William. I'll investigate.. and update if I can. k
