RFDuino compiler errors ?
RadaMikeRadaMike Dallas
edited August 2019 in Cyton
I compiled the RadioHost32Bit code under the rfduino board.
should i be worried and how do i fix these warning?
Warning: Board OpenBCI_RFduino:RFduino:RFduino doesn't define a 'build.board' preference. Auto-set to: RFDUINO_RFDUINO
Warning: Board arduino:OpenBCI_RFduino:RFduino doesn't define a 'build.board' preference. Auto-set to: OPENBCI_RFDUINO_RFDUINO
Warning: platform.txt from core 'RFduino Boards' contains deprecated compiler.path={runtime.ide.path}/hardware/tools/gcc-arm-none-eabi-4.8.3-2014q1/bin/, automatically converted to compiler.path={runtime.tools.arm-none-eabi-gcc.path}/bin/. Consider upgrading this core.
Warning: platform.txt from core 'RFduino Boards' contains deprecated recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} "{build.path}/{archive_file}" "{object_file}", automatically converted to recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} "{archive_file_path}" "{object_file}". Consider upgrading this core.
Archiving built core (caching) in: C:\Users\OQLABS~1\AppData\Local\Temp\arduino_cache_517319\core\core_OpenBCI_RFduino_RFduino_RFduino_55828d07e18502f8cae84d44743120ea.a
arm-none-eabi-g++: error: C:\Users\OQLABS~1\AppData\Local\Temp\arduino_build_95221/syscalls.c.o: No such file or directory
