Unable to obtain data using OpenBCIWiFi / OpenBCI_Python
Hello everyone,
This is my first post here so I want to apologize if is not the correct place for this. I'm completely new using OpenBCI and also Python, so I'm sure I'm making a mistake somewhere.
I'm trying to get data from my Cyton+Daisy via WiFi shield using the code in OpenBCI_Python over my Mac laptop. I wrote a very simple code as is shown below. This code is giving me some information but after that it gets stuck when I call start_streaming() and shows no data.
from openbci import OpenBCIWiFi
import requests
import asyncore
def handle_streamed_data(sample):
print(sample.sample_number)
print(sample.channel_data)
if __name__ == '__main__':
ip_address = '192.168.4.1'
shield_name = 'OpenBCI-79AB'
sample_rate = 500
log = True
timeout = 5
max_packets_to_skip = 10
latency = 5000
high_speed = False
ssdp_attempts = 10
connection = OpenBCIWiFi(ip_address=ip_address,
shield_name=shield_name,
sample_rate=sample_rate,
log=log,
timeout=timeout,
max_packets_to_skip=max_packets_to_skip,
latency=latency,
high_speed=high_speed,
ssdp_attempts=ssdp_attempts)
#connection.connect()
print "Ip de la conexio:", connection.ip_address, "\n"
res_command_post = requests.get("http://%s/all" % connection.ip_address)
ieison = res_command_post.json()
print "Status", res_command_post.status_code, "\n"
print "Text", ieison
print "Pre-streaming"
connection.start_streaming(handle_streamed_data)
print "Post-streaming"
connection.loop()
#connection.disconnect()
What I get when run the code is:
Welcome to OpenBCI Native WiFi Shield Driver - Please contribute code!
Opened socket on 172.16.162.72:57461
Init WiFi connection with IP: 192.168.4.1
Connected to daisy with 16 channels
Ip de la conexio: 192.168.4.1
Status 200
Text {u'latency': 5000, u'name': u'OpenBCI-79AB', u'ip': u'0.0.0.0', u'version': u'v2.0.5', u'mac': u'82:7D:3A:3F:79:AB', u'num_channels': 16, u'heap': 18824, u'board_connected': True}
Pre-streaming
Post-streaming
Does anyone knows what is happening? Also, is there any tutorial/example code/documentation about this? Because the information that I've seen is not helpful for me.
Thanks.
Jayro any update regarding the issue?
Did you manage to find the solution to this problem?
I am also facing the same problem.
Thanks
