DIY Cyton Board: ADS1299 Clamping Signal
I'm developing my own board and using the cyton firmware.
I'm injecting the signal but visualization on the OpenBCI GUI shows the
signal clamped as you can see below:
I have measured some connections in my new board and I realized that voltage
between VREFP (pin 24) is negative regarding to the VREFN (pin 25) what is strange...
I have build here one OpenBCI board, and I have measured in the same pins and
the voltage on VREFP is positive regarding to the VREFN. So my board is probabily
clamping the signal because this error, but I cannot find where is the error that is
causing this to happen. Someone that knows depper the ADS1299 can help me?
A did not change only the DVDD supply to one that has a wide input range but the same
schematic.pdf
"(2) Connect unused analog inputs directly to AVDD."
I connected all the unused all the analog inputs to AVDD, is that a problem?
Theese connections to AVDD can cause the signal is being clamped?
