is it worth switching off the steaming of accelerometer data if I don't use it?
is it worth switching off the steaming of accelerometer data (from cyton to computer) if I don't use it?
Thanks! k
    If you prefer, you can! I don't think it will affect performance.
    thanks!
    Each RFduino radio packet contains 8 * 24 bit channels of data, and 3 * 16 bit 'auxiliary' channels. These aux channels exert no extra overhead on the Cyton, nor on the consuming program.
    The aux channels can also be used to receive external trigger information, when desired to sync an external stimulus event with the corresponding EEG.
    Thanks William. k
