EMG Signal Noise decreases just by switching around the ground and measuring electrodes. Why?
I am currently measuring EMG signals using 3M red dot electrodes and am using a system called open Ephys which uses an Intan RHD 2132 amplifier.
While I am not using the OpenBCI components I believe my question is more generic so I have posted here.
I am using three electrodes one at the upper anterior forearm, one at the anterior wrist and one on the posterior side of the upper forearm. This is to record EMG signals to classify finger movements.
I initially had the ground electrode at the wrist position, which gives a peak to peak noise of 10mV at 50Hz for the upper anterior forearm electrode, but when I switch the ground electrode to the upper forearm on the anterior side the same electrode pair gives noise of 0.75 mV at 50Hz.
Why would the same electrode give such different amount of noise just by switching the electrodes around, why wouldnt it be the same.
For the amplifier the ground and references points are connected.
Thanks in advance
Andrew
