Interconnecting WiFi Shield, Cyton, Arduino and Computer
edited June 2019 in Wifi Shield
I am having some problems in Interconnecting WiFi Shield, Cyton, Arduino and Computer.
My objective is to use Cyton Board to signal acquisition pass the information to a computer for pre-processing and signal processing. Then pass it through WiFi to an ESP module to execute some commands. I already saw some tutorials from the Learning label from OpenBCI site, but I am little lost with this procedures.
Can anyone help me?
Thank you
    edited June 2019
    That configuration does not make any sense.
    IMPORTANT: the WiFi shield is known to have reliability issues across different computer configurations. Using it effectively requires advanced technical skills and programming knowledge.
    If you did want to use those components, it's quite clear that the WiFi Shield should be connected to the Cyton board.
    Cyton+WiFi -> Computer running GUI -> Serial Output to Arduino
    If you are just starting out, please just use the Cyton by itself with the dongle.
    Here is a brand new tutorial on sending Focus data from the computer to an Arduino: Control Arduino Using Your Brain...
