Why is the LIS3DH set to an operational mode that is 'not allowed' in datasheet?
In Table 10 of the LIS3DH datasheet, it states that CTRL_REG1[3] (LPen) = 1 and CTRL_REG4[3] (HR) = 1 is not allowed.
Checking the CTRL_REG1 and CTRL_REG4 LIS3DH registers from a properly functioning Cyton board shows that this is exactly how the LIS3DH is set via the Cyton.
CTRL_REG1 (0x20) = 0x08:
- ODR3 = 0
- ODR2 = 0
- ORD1 = 0
- ODR0 = 0
- LPen = 1
- Zen = 0
- Yen = 0
- Xen = 0
CTRL_REG4 (0x23) = 0x18:
- BDU = 0
- BLE = 0
- FS1 = 0
- FS0 = 1
- HR = 1
- ST1 = 0
- ST0 = 0
- SIM = 0
To confirm, I double-checked the OpenBCI_32bit_Library C++ file and header file, and they show:
#define SCALE_4G 0x10 //(b00010000) // +/- 4G sensitivity
void OpenBCI_32bit_Library::initialize_accel(byte g)
byte setting = g | 0x08; // mask the g range for REG4
pinMode(LIS3DH_DRDY, INPUT); // setup dataReady interupt from accelerometer
LIS3DH_write(TMP_CFG_REG, 0x00); // DISable ADC inputs, enable temperature sensor
LIS3DH_write(CTRL_REG1, 0x08); // disable accel, low power mode
LIS3DH_write(CTRL_REG2, 0x00); // don't use the high pass filter
LIS3DH_write(CTRL_REG3, 0x00); // no interrupts yet
LIS3DH_write(CTRL_REG4, setting); // set scale to g, high resolution
LIS3DH_write(CTRL_REG5, 0x00); // no boot, no fifo
LIS3DH_write(CTRL_REG6, 0x00);
LIS3DH_write(REFERENCE, 0x00);
DRDYpinValue = lastDRDYpinValue = digitalRead(LIS3DH_DRDY); // take a reading to seed these variables
Any reason why this is and what actual operation mode is the accelerometer in? Would this affect the hex conversion to 'G' value?
Wondering if this would put the LIS3DH in some weird limbo mode that may or may not work all of the time.
Thanks
