Help with 50 Hz noise bursts
Hi!
I've been using the Cyton board for a while with no problem whatsoever. Recently I've been trying to use some dry electrodes (the well-known FRI long spiked ones) to record alpha waves / low frequency SSVEPs. I use a gold cup electrode fixed to my ear lobe with electrode cream as ground, a dry electrode in FP1 as reference and a dry electrode in O1 as signal source; all pins apart from the first are turned off and SRB2 is used as reference.
Here comes the issue: sometimes, for prolonged (but not easily reproducible!) time periods, sudden high intensity "50 Hz bursts" can be seen in my recordings.
Follows an image:
Here I'm using OpenViBE, but the problem can be seen in OpenBCI_GUI as well. I implemented a 50Hz Notch filter coupled with a 2 Hz - 70 Hz bandpass filter.
There are no devices running around me, apart from my battery powered laptop (not connected to AC).
An additional note: of course it's not a 50Hz-only noise - actually its components range from 50 to about 60 Hz, with some sparse low frequency harmonics as well. If a better spectral definition is needed, tell and I'll provide.
Any ideas on how to solve this?
Thanks for any response.
Luca
(I may have posted this twice due to a browser hiccup. Sorry!)
Luca
