Porting the OpenBCI GUI to openFrameworks
There is growing interest recently to port the OpenBCI software GUI to openFrameworks. Grant and Andy, I know you guys were working on this at the first hackathon. Do you think you could link to your code from this thread? Daniel Goodwin, who is working on the BrainWriter project, wants to expand upon your oF code.
I'm also personally interested in seeing this happen ASAP, because oF is my preferred creative coding language.
-Conor
-Conor
My architectural hypothesis for EEG software is to write it in two modules: a computational modules (in Python) and a graphical interface layer (in OpenFrameworks), with an OSC bridge between the two. I already have a working system of this which I could gladly share, and would also be great to hear you thoughts on this. I could imagine there being some lively debates about this structure, and I'd welcome feedback/perspectives.
Cheers,
Dan
That's a cool suggestion. Separating computation from GUI is usually a very good idea. Implementing those two functions in different languages (Python on C++/OpenFrameworks) can also be a good idea because you can choose the language that is best suited to the task and you can leverage libraries that might only exist in one of the languages.
In my opinion, though, it would be best to keep the barrier to entry as low as possible. If we were to use two different languages, it requires a new user to know both languages *and* to set up the toolchain for both languages. These are two sizable hurdles for newbies.
For my own contributions (I've done the stuff in Processing), I've chosen to stick with one language (Java/Processing) and to stick with the toolchain that is the easiest to setup (Processing).
That's just my own opinion, though. I definitely like a diversity of opinions...in fact, all this talk of Python and OpenFrameworks is making me think of putting on my big boy pants and finally learning one of these new languages. Gotta keep the mind sharp!
Chip
Is there a good reason for using openFrameworks other than you already know it?
I actually am brand new to OpenFrameworks, and I picked it up specifically for my project with OpenBCI (which will involve an interactive exhibition and generative art). As far as I can see, it's a tie between Processing and OpenFrameworks for best front end tools for those purposes.
That said, I totally agree that Python is great for early programmers and is great for the computational libraries available by the open source community. I'd like to contribute to the software project in a way that helps as many people as possible.
Alistair, do you know much about what you want the software to do for your project?
http://kivy.org/#home
some of the many other python GUI building apps:
http://www.cosc.canterbury.ac.nz/greg.ewing/python_gui/
http://qt-project.org/wiki/PySide
https://wiki.python.org/moin/TkInter
As this is open source, build a GUI using whatever tools you like. It doesn't stop anyone else writing a different one. The question is how difficult will it be for someone to build something on top of your work in openFramework compared to Python?
If you follow the thinking of Eric S. Raymond from ’The Cathedral and the Bazaar’, open source development requires community and splitting community by having two branches wastes intellectual resources.
I think if you want lots of people to use this hardware, why make it difficult to start? If you consider the path of someone not from a computer science background, there are now many MOOC's that teach python and they will get a return on effort sooner with python than C.
If the backend to the front end is python they have a chance of finishing a project without stopping to learn other languages and how to get them to interact.
Again, the beauty of open source is that everyone has the information to build whatever they want, in whatever language they prefer. The danger is that the project will fizzle because the starting communities' effort wasn't focussed and new people were turned off by the barrier to entry.
I'd also suggest that writing drivers for BCI2000 and OpenViBE should be prioritised and the Pyff, Mushu, Wyrm project is worth supporting too. That would tap into a large chunk of the existing BCI community who would love to have open source hardware.
I created a simple open source GUI app in Openframeworks for the MindWave hardware - https://github.com/trentbrooks/BrainWaveOSC/tree/develop. It also outputs the EEG data via OSC, and allows recording/playback of data. While this has been created specifically for the Mindwave hardware- i don't think it would be difficult to port for OpenBCI as it also uses raw serial communication to connect to the hardware via bluetooth.
Anyway, if you need a hand with any of the OF stuff - let me know.
Good luck,
Trent
Since the last posting I've been getting stronger with OpenFrameworks, and so I've created ofxOpenBCI: while it's v0.1 software, it should help anybody else building openFrameworks applications
https://github.com/dgoodwin208/BrainWriter/tree/master/ofxOpenBCI
I apologize for not responding sooner, thanks for the great posts.
As far as JavaScript signal processing, there appears to be a fair amount out there, so that might be divided somewhat between the server and UI.
https://www.google.com/search?q=javascript+signal+processing
https://www.google.com/search?q=python+signal+processing
My guess is that for BLE, folks will settle on working with fewer channels or less sample depth (16 vs. 24 bits) to keep the link throughput manageable.
I have data vis code I can use or I may use a framework like kiva but how do I access the live data is my first step. Just want to show a stream of numbers for each sensor in a browser first.
Conner, Murph,
Are there any tutorials or examples on how to read from the dongle, say in Python?
http://openbci.com/forum/index.php?p=/discussion/226/accessing-openbci-v3-from-python
Has anybody continued down the C++/OpenFrameworks path? I began porting the Gui to C++ this week, starting with the works of Dan and roman3017.
I have barely started - see https://vimeo.com/150067994 - but I am determined to continue porting until the whole Gui is finished. If you need anything C++ related in the code, now would be a good time to ask for it.
Has anybody else ported any of the other Gui elements? If so, it would be great for me to hear of it now so I can include that code.
I personally think that having a C++ and OpenFrameworks solution only is not a bad idea. So far, I only checked the Java version but I will look at the python code before continuing to port for sure.
I'm new to GitHub so please bear with me. I will release the source code once it's finished.
I'd be happy about any feedback,
Holger
