noise at 20hz - unreliable signal ? [resolved]
I am unable to gather data due to persistent noise at 20hz. I have moved my laptop all over the apartment and the noise will not go away. When nothing is connected to my Ganglion, all of the channels are quiet, basically flatlined. It is also that way when I attach my lead to the reference using an alligator clip. The moment I have a lead attached to my Ganglion, there is a huge amount of noise, and when viewing the FFT plot there is a large spike at 20hz. This happens even when the electrode is not attached to me and I lay it on my bed. It also happens when I have no electrode attached. I have no idea what the cause could be, anybody have any ideas?
Chiming in for those who end up on this thread. I was also having 20HZ noise with ganglion, dry electrodes and the headband set up. The peak in the spectrum around 20 Hz was 1-2 orders of magnitude above the standard 1/f PSD shape. As wjcroft said, floating eletrodes (not connected to anything) can act as antennas. So I figured I might not have a good connection. I tightened the headband and the 20 Hz noise went away. Its pretty tight and clean signals are still a bit intermittent in the comb electrodes back (as compared to the flat electrodes on my forehead).
TLDR: Check your connections. Make sure your electrodes are making good contact with your skin.
