User.py does not work
Dear,
I tried to run the command below (Windows 10, board cyton):
python user.py -p COM3
And I get the following message:
WARNING: no plugin selected, you will only be able to communicate with the board. You should select at least one plugin with '--add [plugin_name]'. Use '--list' to show available plugins or '--info [plugin_name]' to get more information.
Board type: OpenBCI Cyton (v3 API)
Port: COM3
------------SETTINGS-------------
Notch filtering:True
user.py: Logging Disabled.
File "user.py", line 114, in <module>
board = bci.OpenBCIGanglion(port=args.port,
AttributeError: module 'openbci.cyton' has no attribute 'OpenBCIGanglion'
Has anyone had the same problem? I followed the instructions but without success.
After that, I tried to run the script test.py from the Scripts folder. I was able to successfully sample them, however, I would like to know how I can stop data streaming because the code runs indefinitely. Follow the code below:
import sys; sys.path.append('..') # help python find cyton.py relative to scripts folder
from openbci import cyton as bci
import logging
import time
def printData(sample):
#os.system('clear')
print("----------------")
print("%f" %(sample.id))
print(sample.channel_data)
print(sample.aux_data)
if __name__ == '__main__':
# port = '/dev/tty.OpenBCI-DN008VTF'
#port = '/dev/tty.usbserial-DB00JAM0'
port = 'COM3'
# port = '/dev/tty.OpenBCI-DN0096XA'
baud = 115200
logging.basicConfig(filename="test.log",format='%(asctime)s - %(levelname)s : %(message)s',level=logging.DEBUG)
logging.info('---------LOG START-------------')
board = bci.OpenBCICyton(port=port, scaled_output=False, log=True)
print("Board Instantiated")
#board.ser.write('v')
board.ser.write('v'.encode())
time.sleep(10)
board.start_streaming(printData)
board.print_bytes_in()
Thank you in advance for helping me.
