MyoWare and EMG, need to adjust SRB, Bias?
Apologies for having to ask such a basic question, but all of this is very new to me. My question has to do with understanding the relation between BIAS, SRB, and the desired measure.
So, in the first "setup" tutorial for the Cyton, we connected one electrode to a juicy muscle (the one we wanted to measure), and another to our wrist (which hasn't much muscle). The arm muscle electrode was connected to the bottom 4 pin, and the wrist to the top 4 pin. These were then taken OFF SRB and BIAS in the console, and there was a clear explanation for this. So far so good.
Now, in setting up the MyoWare, two wires go to the same top and bottom pins on a given channel, as above. But a third wire (the R (likely reference) wire) goes to the top BIAS pin. However, in this case I'm not given any instruction to turn off SRB and BIAS on the hardware console. Why is that? In the first case the explanation was:
"The reason we do this is because the uV values for EMG and EKG are much bigger (and easier to pick up) than the EEG signals on channels 2 and 7. As a result, we want to prevent channel 4 from influencing the common mode noise rejection of the BIAS, as well as remove it from the EEG reference channel (SRB2)"
So isn't that a good idea to do here as well? If it isn't necessary, why not? I'm just trying to understand what is going on with these connections...
Thanks for your help!
