'numPacketsDropped' errors every ~ 15 to 30 seconds, when streaming via WifiShield and TCP
I'm using a Cyton (firmware V 3.1.1) , Daisy and Wifishield (V 2.0.5) and when streaming data via TCP the output from the terminal of the compiled version of the OpenBCI GUI (V 4.0.4, HUB V 2.0.5) reports that groups of ~20-30 packets are being dropped every 15-30 seconds. I am using Wifi-direct. When searching the codebase for a string in the error message ("numPacketsDropped") it points to the InterfaceHub.pde file. The description at the top of that file speaks about the Ganglion explicitly (is this just an artefact from the code being re-used and the comments not being changed?)
Furthermore, when I use the UDP protocol instead, only one instance of packet dropping is relayed: immediately on starting the stream. My goal is to minimize the latency and drop-rate of packets, do you have any advice? Am I wrong in assuming that this 'packet drop' error is network specific, and not related to gui rendering of the packets data?
Any feedback would be appreciated!
William:
-I was initially using 1000hz and 16 channels with 10ms latency over both
TCP and UDP. As per your suggestion, changing to 5000hz while using
TCP reduced the packet drop issue to an occurrence ~once every 5
minutes. Using the UDP protocol at 10,000hz seems to be even more
reliable, however my sample size is small at this moment. What
is the threshold for packet drop reporting? The smallest amount of
packet drops that I have seen reported is 8, would the OpenBCI_GUI
software report 1 packet dropped?
stating that the WifiShield firmware is out of date, which prohibits UI
initialization and data streaming. WifiShield firmware is V 2.0.5 which
is the most current version on
I have tried downloading the pre-compiled version of the OpenBCI GUI (v
4.0.3) and Hub (V 2.0.4) but I receive the same error message when
attempting to use UDPx3.
That information was highly valuable, especially the background on UDPx3. Thank you. Using the UDPx3 protocol would be highly ideal.
If Sean doesn't have any other suggestions right now I'll try updating the Cyton firmware and see if I have any more luck.\
