ADS124S08IPBS vs ADS1299
Can I use ADS124S08IPBS instead of ADS1299 for making my own Cyton board.
    Siddhant, hi.
    Have you compared the two data sheets? There appear to be other differences than just the number of channels. May also require firmware changes.
    There are also lower channel count devices in the ADS129x family. These may be closer to the ADS1299,
  • @wjcroft I got ADS1298IPAG. On comparing the datasheets the only difference is in the data rate, CMRR and Programmable gains.
    ADS1298 - Data Rate - 32kSPS
                     PGA - 1,2,3,4,6,8 or 12
                     CMRR - -115dB
    ADS1299 - Data Rate - 16kSPS
                     PGA - 1,2,3,4,6,8,12 or 24
                     CMRR - -110dB
    What changes in the firmware will be made to account for these changes. Thanks, you have been of great support till now. I really appreciate you for the work.
    As far as I can see from your list above, you would need to look at the firmware sections that deal with the PGA settings. I believe Cyton defaults to setting the PGA to max, x24. You could simulate this by running at x12 and multiplying all your received samples by 2.
    Other sections of the firmware allow the PGA to be set individually per channel. In that case setting to 1,2,3,4,6,8,12, will be compatible. When the gain is set back to the default x24, you would then re-engage the simulation.
    There may be other differences.
    Is this a big cost savings for you??  I would think that your hours of time spent adapting to another ADS model, would immediately cancel the dollars difference between the two chips.
