"A float is required" problem with OpenBCI_NodeJS_Ganglion
Repo in question: https://github.com/OpenBCI/OpenBCI_NodeJS_Ganglion
Hey folks,
I'm running a research topic and we decided to work with the Ganglion board.
I've been trying to look for any method that will let me stream or send data and one of our hopeful options was using OpenBCI NodeJS Ganglion
I've been able to successfully run all prerequisites in order to run it, however I'm stumped by why it keeps asking me "a float is required."
(Ignore file directories, I've been trying to experiment with some of the node package incompatibilities in order to see if that was the problem)
I've also replicated the problem on a Linux partition to see if it was problems with BLE packages, only to get the same "a float is required" error.
If anyone has suggestions, or has ran into something similar recently, I'd appreciate if you could lead me to the right direction.
Cheers!
Hey folks,
Cheers!
