Un-stable timestamps in .txt file created by the openBCI GUI
Board: Ganglion
Recording: MacBook Pro (2018), MacOs:10.13.6 (built-in bluetooth)
In my output(s), samples seem to arrive not at all in line with a sampling rate of 200. Differences between two succeeding timestamps vary from 0 (two samples send in one packet I guess?) up to almost 100ms.
Also, it appears that several consecutive points can have exactly the same timestamp.
In addition, there are sometimes (although not often) less than 200 samples within 1s (although the sample number 0-200 does not show any jumps (except from 200 back to zero)).
So overall the recoding holds less samples then supposed over a given time.
Please see this small snippet as an example.
99 11.7700000000000 13.5500000000000 14.0200000000000 6.37000000000000 0.128000000000000 -0.0960000000000000 -1.00800000000000 "22:18:11.519" 1547327891519.00
100 10.3200000000000 16.1900000000000 12.9700000000000 12.8300000000000 0.128000000000000 -0.0960000000000000 -1.00800000000000 "22:18:11.519" 1547327891519.00
101 5.90000000000000 3.18000000000000 11.2800000000000 3.26000000000000 0.128000000000000 -0.0960000000000000 -1.00800000000000 "22:18:11.520" 1547327891520.00
102 5.36000000000000 -0.740000000000000 10.0900000000000 8.30000000000000 0.128000000000000 -0.0960000000000000 -1.00800000000000 "22:18:11.520" 1547327891520.00
103 10.4800000000000 6.56000000000000 7.93000000000000 7.05000000000000 0.128000000000000 -0.0960000000000000 -1.00800000000000 "22:18:11.615" 1547327891615.00
104 12.3300000000000 3.96000000000000 10.1900000000000 4.58000000000000 0.128000000000000 -0.0960000000000000 -1.00800000000000 "22:18:11.615" 1547327891615.00
105 11.6600000000000 8.66000000000000 8.67000000000000 6.91000000000000 0.128000000000000 -0.0960000000000000 -1.00800000000000 "22:18:11.616" 1547327891616.00
106 6.48000000000000 5.03000000000000 2.65000000000000 5.74000000000000 0.128000000000000 -0.0960000000000000 -1.02400000000000 "22:18:11.616" 1547327891616.00
107 10.4400000000000 3.73000000000000 10.0400000000000 10.3800000000000 0.128000000000000 -0.0960000000000000 -1.02400000000000 "22:18:11.616" 1547327891616.00
108 12.5300000000000 3.87000000000000 10.5500000000000 12.2400000000000 0.128000000000000 -0.0960000000000000 -1.02400000000000 "22:18:11.616" 1547327891616.00
So how can I identify the timepoint(s) of the dropped samples?
Another question:
Is (when der are no sample drops) the sample number 0 supposed to hold the "uncompressed" absolute value which is send each second and the other 200 samples (1-200) stem from the deltas?
So do I have in fact 201 sample each second?
best,
dom
So when I get it right, the ganglion is supposed to provide 201 samples / s (not 200)?
