All 8 channels railing on headset
edited September 2016 in Cyton
I'm using an OpenBCI 8-channel headset, and I'm experiencing noise on all channels. No power is flowing to the laptops on the table (they're all on battery), and all the pins are secured on. The only peculiar thing is that when shorting each channel to ground, one appears to be on by default. Could this be a software (error-checking) bug? Any additional advice (besides what's listed on the main troubleshooting website?)
Eric
    Eric, hi.
    Can you try a test with the gold cups as shown on the tutorial,
    http://docs.openbci.com/tutorials/01-GettingStarted
    Try swapping around your electrode leads, you may have a bad reference (SRB2) connection (wire or connector).
    Another test you can try is to use a glob of Ten20 paste or alligator clips, to connect together all of your channels, plus SRB2, plus Bias. This should result in about 0 microvolts on all channels.
  • Hello William,
    The tutorial and linking all the gold cups together with the paste (I used a Glycerin solution, since I don't have the paste) yielded the same results. I also tried switching the SRB2 around but saw no change as well, and since that didn't work for any connector, I can only conclude it's a problem with the connector or the OpenBCI itself.
    Do you know of any other test methods?
    Thank you,
    Eric
    The paste contains conductive saline solution and is adhesive. Do you have alligator clips? Or do you have any jumpers that use the same female header connector? If you short one or more channels to the SRB2 pin (and Bias), this should produce 0 uV. Are you sure you are using the pins closest to the board?
