Python installation pre-requisites
edited August 2014 in Software
Hi, saw the python library was uploaded. Trying to run it, I'm getting the following errors:
$ python run.py
File "run.py", line 1, in <module>
from traits.etsconfig.etsconfig import ETSConfig
ImportError: No module named traits.etsconfig.etsconfig
scratches@scratches-laptop:~/gh/eeg/eeg_sensor$ python run.py
Looking through the files, while there is a full python.exe windows installation, I wasn't able to find a module called traits anywhere in the files?
  • I guess the pip freeze would have....
    pip install traits traitsui pyface mpltools PySide
  • Still having difficulty getting this up...
    $ python run.py
    File "run.py", line 10, in <module>
    import traitsui.api as tui
    File "/usr/local/lib/python2.7/dist-packages/traitsui/api.py", line 35, in <module>
    from .editors.api import (ArrayEditor, BooleanEditor, ButtonEditor,
    File "/usr/local/lib/python2.7/dist-packages/traitsui/editors/__init__.py", line 22, in <module>
    from .api import (toolkit, ArrayEditor, BooleanEditor, ButtonEditor,
    File "/usr/local/lib/python2.7/dist-packages/traitsui/editors/api.py", line 10, in <module>
    from .code_editor import CodeEditor
    File "/usr/local/lib/python2.7/dist-packages/traitsui/editors/code_editor.py", line 36, in <module>
    class ToolkitEditorFactory ( EditorFactory ):
    File "/usr/local/lib/python2.7/dist-packages/traitsui/editors/code_editor.py", line 48, in ToolkitEditorFactory
    mark_color = Color( 0xECE9D8 )
    File "/usr/local/lib/python2.7/dist-packages/traits/traits.py", line 487, in __call__
    return self.maker_function( *args, **metadata )
    File "/usr/local/lib/python2.7/dist-packages/traits/traits.py", line 1191, in Color
    return ColorTrait( *args, **metadata )
    File "/usr/local/lib/python2.7/dist-packages/traitsui/toolkit_traits.py", line 7, in ColorTrait
    return toolkit().color_trait( *args, **traits )
    File "/usr/local/lib/python2.7/dist-packages/traitsui/toolkit.py", line 109, in toolkit
    _toolkit = _import_toolkit(ETSConfig.toolkit)
    File "/usr/local/lib/python2.7/dist-packages/traitsui/toolkit.py", line 51, in _import_toolkit
    return __import__( name, globals=globals(), level=1 ).toolkit
    File "/usr/local/lib/python2.7/dist-packages/traitsui/qt4/__init__.py", line 24, in <module>
    import toolkit
    File "/usr/local/lib/python2.7/dist-packages/traitsui/qt4/toolkit.py", line 24, in <module>
    from pyface.qt import QtCore, QtGui, qt_api
    File "/usr/local/lib/python2.7/dist-packages/pyface/qt/QtCore.py", line 20, in <module>
    from PySide.QtCore import *
    ImportError: libpyside-python2.7.so.1.2: cannot open shared object file: No such file or directory
    Have installed all the above, including PySide.
