after opening eyes, time lag until alpha extinguished
I really need your help.
I use
32bit Board Kit (8-channel), win 7, notebook
The problem is:
When running the program, there is time lag which mean
In the brain
when i close my eyes, there is alpha wave.
when i open my eyes, there is no alpha wave.
In my measurement, when i open my eye, the computer still detect alpha wave due to alpha wave detected within time lag about 1 second
What i have tried but still not work:
I have to do a real time measurement instead of saving SD card
I have try change FTDI > Port > to 1 ms( from
http://openbci.com/forum/index.php?p=/discussion/199/latencytimer-inbuffersize-for-os-x-new-info-plist
I can't change the buffersize (but i dun;t know where to change it )
What I need:
the processing is at the same step as the data streaming from openbci
What I compromise:
1. can I reduce data streaming so that reduce the workload of the the processing?
2. or other possible solution
really thanks for your help .
The link you mentioned is for Mac users.
re: slight delay upon opening eyes before alpha extinguishes: this may be just normal physiology for the person you are measuring. For example with myself, I've done a lot of Zen style open eye meditation. So I have
some alpha present even with my eyes open.
re: Processing workload. Your modern Win7 notebook should have plenty of CPU cycles to run the GUI app.
As mentioned previously, your personal alpha generation may be laggy like this. Nothing is likely wrong either with your equipment or your physiology.
