OpenBCI Schematic to PCB problem
I'm having trouble transferring from Schematic to PCB, I keep getting the following errors in the DesignSpark report:
Could not load component "C" package "0402" into target design.
Could not add "C23" component "C" package "0402" to target design.
Could not add "C20" component "C" package "0402" to target design.
Could not load component "BATT" package "SM" into target design.
Could not add "B1" component "BATT" package "SM" to target design.
I'm assuming that packages 0402 and BATT are part of the openBCI library files? Has anyone else run into this issue?
    This may be an issue with the latest version of Design Spark? If you can find the version 6, try that.
    Also, make sure that you have the library files loaded correctly.
    Worst case, I think you can select the footprint to edit, and then save it. That way you won't have to re-design the parts.
