sketch size differs, Arduino vs Mpide compilers
For OpenBci_32bit code, both compilers do not agree...
"Verify / Compile " gives :
From Arduino :
Sketch uses 8,320 bytes (6%) of program storage space. Maximum is 122,880 bytes.
Global variables use 424 bytes of dynamic memory.
From Mpide :
Binary sketch size: 54012 bytes (of a 122880 byte maximum)
Which one is right/best ?
I am a little bit shy as regards the uplaod on the card(map), there is so much problem brought back(reported) on the forum.
A preference? Which one is the most reliable?
Thank you,
Yannick.
From Arduino :
From Mpide :
Thank you,
Yannick.
