OpenBCI for medical research in neurointensive care (EEG)
Hi all,..
I am brand new to this place, almost new to the concept of BCI and somewhat new to EEG in general.
I am a medical doctor. I practice as a senior consultant in anesthesia, specifically in neuroanesthesia and intensive care in Odense, Denmark.
I have for some time now been interested in the use of continuous EEG monitoring in intensive care of neurointensive patients. My hospital of course have neurophysiologists but they are more focused on short term "full frame" EEG monitoring.
There are commercially available EEG modules for continuous EEG monitoring, but they are either very expensive or limited in scope / accesibility of the data.
My hope is that OpenBCI will be my saviour. I am quite tech savvy although not an engineer or programmer of course. I do however have some experience "programming" in the Unity3D Game environment.
My main question for starters is this:
IS OpenBCI licensed as medical-grade equipment whereby it can be used freely in a hospital setting? This is the first and imperative step for me since otherwise I cannot do any research with the module at all.
In case it is I have loads of other questions and I hope to find others who have similar interests or at the very least someone who can point me in the right direction on some of the more technical issues ;-)
Thx in advance,
Jesper Broesby, Denmark
CE Certification for medical devices cost estimates are in the tens of thousands of dollars. So OpenBCI has not pursued this. Also the nature of the OpenBCI board, being not enclosed would be a disqualifying factor. OpenBCI IS being used by researchers worldwide, but would likely not qualify in an intensive care medical application. Some examples of costs,
https://www.google.com/search?q=iec+60601-1+certfication
https://en.wikipedia.org/wiki/IEC_60601
https://www.quora.com/What-is-the-average-cost-to-get-FCC-and-CE-certification-for-a-very-simple-electronic-gadget
[but NOT a medical device]
http://www.medicalelectronicsdesign.com/blog/medblog/how-scary-iec-60601-1
[WAY scary, as in $40,000 and up.]
Anesthesia applications typically use something called the BIS, Bispectral Index,
https://en.wikipedia.org/wiki/Bispectral_index
I believe some of the calculations used are public knowledge, they are looking at activity in the gamma and infralow (below .5 hz) frequency bands. So it would probably be possible to emulate a BIS calculation, but certainly would not want to be doing this in a critical care environment.
Do you have access to a raw EEG stream from a medically approved device? Then you could pursue some calculations on your own medically certified computer to which it is connected.
http://www.brainmaster.com/kb/entry/559/
In other words, 510K manufacturers of such equipment can ONLY sell to you, if you show them your state license. For example, licensed psychologist or M.D., etc.
The entire field of BCI has escaped this onerous requirement by NOT registering with the FDA. CE Certification has no such sales restrictions.
