chipKIT DVDD not 3.3v -> replace D9 diode
[original thread titled: My OpenBCI 32-bit does not work recently.]
My OpenBCI 32-bit does not work recently. the phenomenon is that could not output any date, and even the blue LED light does not work.
Any suggestion on how to follow up debug or locate this issue?
-Anfeng
-Anfeng
* Have you altered the firmware on the main board (or dongle), or is it still running default firmware.
* Does your PC recognize the dongle (port shows up in device manager).
* Is it possible the on/off switch on the main board is broken? Try the BLE position, which is currently equivalent with PC.
* When did you notice the board stop working, what was happening just before that?
thanks for the comments, please see the comments below:
* What is your battery voltage? What type of AA cells?
[Anfeng]: 1.5V (count: 4)
[Anfeng]: No, still running default firmware.
[Andy]: Yes, the PC recoganised the gongle. And ports shows up in Processing GUI (COM8)
[Andy]: I am not sure if on/off switch on the main board borken. I did switch to BLE position, but no lucky :-(.
[Andy]: One week ago. I did not remember I did any specific action bofore. Just one day of one week ago, I connect the bettery, but the BLUE LED light did not work, then I could not get any date from the processing GUI.
By the way, I have another OpenBCI 32-bit board, that one works well in the same environment. I mean use the same battery. Let me know if you have any suggestions that I can do some comparision testing with good one.
-Anfeng
I measured the incong TOTAL battery volatage, the value was 6.11v. However, when I measure DVDD and GND header pins, the value was 0, not 3.3v.
Looks like some component does not work :-(.
Let me know if you have any suggestions to make more troubleshooting.
Thanks & Regards,
-Anfeng
http://openbci.com/forum/index.php?p=/discussion/403/board-not-turning-on-polarity-protection-diode-failed
Finally, I got diode D8 does not work, will replace it with new one.
By the way, any idea why D8 does not work? Do we need to change to any type of diode?
However, I have someone replace D8, but no lucky. It is still does not work. Even volt is 0.01v.
By the way, looks like D9 works well, the volt is around 5.46v
Any other suggestions? Thanks
what I said 5.46V is the voltage drop across the D9.
Looks like I did not isolate the issue :-(.
Anyway, Here is the some voltage detailsAfter I changed the D8, here is the details:
GND ~ DVDD: 0.10 V
GND ~ AVDD: 0.03 V
GND ~ AVSS: 0.00 V
No worry about doing these "tedious" things, I am happy to do anything to isolate the problem.
drop across D9 when power on: 0.01v
drop across D9 when power off: 0.07v
In order to confuse you, I paste the my measurement picture link below for the referece. After all, I am not the electrical engineer, but software engineer.
http://pan.baidu.com/s/1pJ3lLLx
Both of my two boards works well now after replaced the D9.
