32bit Chipkit board won't connect to dongle.
I'm at the part of the getting started document where it says to switch on the board and the light will blink 3 times. The light is just turning on with no blinking and then I can't find the board in the GUI. I did everything without trouble until this point in the tutorial and tried restarting everything a few times. The batteries are fresh.
I have windows 8.1 and used the setup executable on here for the windows FTDI drivers.
Thanks for the help. I'm stuck.
But I wonder that the red Tx LED doesn't flash when the dongle tries to connect. (so it doesn't send)
Only the yellow Rx LED flashes two times.
@wjcroft, I saw the new COM port showing up in the device manager, it was COM6 resp. COM10 resp. a dev. I selected it and started. (When I removed the dongle it disappeared). I tried it on a PC IBM9229 and on a Thinkpad W520 with Windows XP resp. Win7 and fedora22 on different USB ports that work fine with USB sticks etc.
