EEG data analysis, delta band strongest
Hello, when analyzing EEG data, I want to observe the PSD power distribution of 5 frequency bands(Delta,Theta,Alpha,Beta,Gamma). The 8-channel electrode positions used are shown in the figure below.
The PSD distribution of the original data is shown in the figure.The psd power of delta is two orders of magnitude higher than that of other frequency bands! ! ?
Secondly, when I remove the EOG signal using detrending, a 4th order Butterworth filter (0.5 Hz to 45 Hz), a 50 Hz notch filter, and ICA, the low frequency energy is slightly reduced, but still high. Am I missing some processing step?
I need to use the EEG signal for fatigue detection, and I cannot filter out the delta and theta bands because the energy of the delta and theta bands may increase when I am tired. But now the energy at the low frequencies is so high that it is difficult for me to analyze.
Can you tell me if this is normal? Is there something wrong with my process steps?
Hi Fnngn,
This is normal. Read some of the search results below.
https://www.google.com/search?q=eeg+1/f+power+law
