Use Cyton with ML Model trained on NinaPro
Hello Everyone,
i am part of a student initiative at a German university and we are trying to make a prototype for a prosthetic arm, that can be controlled using the cyton as EMG.
We have noticed, that the value ranges for the NinaPro dataset are quite different from the RAW and BDF output of the OpenBCI GUI. We are struggeling finding out the concrete reason for the difference in the data structure between the cyton and the thalmic myo armband.
So tl;dr :
How can we convert the RAW or BDF output from the OpenBCI GUI to match the data structure used in the NinaPro dataset? Does anyone have experience with that?
Thank you in advance!
Hi NeuroTx,
I can only suggest that you try to mimic the EMG signal processing steps as closely as you can: sample rate, bandpass and notch filtering, etc. For reference here is the website and one of the papers:
https://ninapro.hevs.ch/
https://jneuroengrehab.biomedcentral.com/articles/10.1186/s12984-019-0488-x
"A quantitative taxonomy of human hand grasps"
So one of the issues might be the large difference in sample rates between 250Hz and 2000Hz. There may be ways to compensate for this.
If the original experiments were done with 22 channels, it may be possible that you are trying to use the 16 channel Daisy configuration. Unfortunately this drops the sample rate to 125 Hz, so that is a substantial reduction. There may a trade off between the number of channels you use and the sampling constraints.
Thanks for your response!
We also noticed that NinaPro data has 8 bits values, exactly as pointed out in here
The OpenBCI on the other hand, doesn't seem to use the same preprocessing, which makes it difficult to match the NinaPro format. So is there anything similar in OpenBCI?
The link you gave is pointing to info on the 'Myo Gesture Control Armband'. This is a low resolution 8 bit device.
The previous link I gave above was to the CyberGlove 2, a completely different device.
https://www.est-kl.com/cyberglove-systems/
https://www.est-kl.com/cyberglove-ii/
Furthermore Cyberglove appears to be sensing joint rotations & motions. NOT EMG.
