Bluetooth getting disconnected while streaming in Cyton
Hi All,
I am using Cyton + Daisy setup to record EEG Stream data alongside the SD Card recording.
I am recording the stream for 5 mins, 15 mins respectively. And while recording, the cyton board's bluetooth is getting disconnected after 3 mins (For 5 mins of SD recording being selected), and is disconnected after 9 mins of streaming (For 15 mins of SD Card recording being selected).
Kindly guide on what can be the issue on this unstable bluetooth connection and what can be done to solve this particular issue.
@wjcroft It will be great if you can help out on this.
Thanks & Regards,
Pluto
A common strategy to increase radio connectivity between the dongle and mainboard, is to use a usb extension cord to position the dongle closer to the mainboard. Also check your environment for other Bluetooth devices, which may be interfering with reception. The OpenBCI GUI allows the radio channel to be changed, as another possible workaround.
https://www.google.com/search?as_q=usb+extension+cord&as_sitesearch=openbci.com
