Accelerated Learning
So I want to see the brain waves of a user whilst performing accelerated learning techniques. Can the Open BCI platform take out the EEG signals in a easy to comprehend way? I.E show the amount of Alpha/Beta/Theta/Delta/Gamma waves at different regions of the brain corresponding to the different electrodes position?
You can easily setup filters to show the amplitudes of these different bands. See the BrainBay tutorial for an example of a very simple neurofeedback protocol measuring alpha and beta bands from a sensor at one point.
Note that, surface EEG like this is not precise enough to localize "different regions" and networks of the brain. A sensor at the scalp picks up activity from a very wide area. (Nunez estimates one EEG sensor is picking up ensemble activity from 6 square cm of area.) To really see network and region activity requires what is called "source localization" or "the inverse solution": using a large number of sensors and computing activity at 3D volume pixels (voxels).
As just one example, see this paper,
http://airccse.org/journal/sipij/papers/4413sipij04.pdf
Advanced Brain Monitoring (ABM) says they have a 24 channel system that works along these lines. Although 24 channels is near the minimum number of channels needed,
http://www.advancedbrainmonitoring.com/accelerated-learning/ see TedX video
EGI uses much denser arrays. Some references on the page as well,
http://www.egi.com/research-division/research-division-bel/accelerated-learning
Scholarpedia on source localization,
http://www.scholarpedia.org/article/Source_localization
Now what constitutes research into brain network activation during learning, can be different from practical applications involving simpler paradigms.
DARPA is said to be working in these areas and ABM has participated in that. In the video below they show a simple 6 or 9 channel sensor montage with amateur archery trainees said to be achieving higher accuracy with neurofeedback coaching. (To increase simultaneous alpha and theta.) Since this is not using source localization, this is something you could do with OpenBCI and/or Brainbay or custom software.
http://www.advancedbrainmonitoring.com/abm-on-through-the-wormhole Video
Paper describing the ABM neurofeedback algorithms used with golf, archery, etc. Basically training to increase relaxation, receptivity and "enter the zone".
Most likely these techniques of accelerated learning for meditative athletic disciplines, will not generalize to all situations in which you would want to facilitate cognitive learning. ABM carefully chose activities that were more easily measured and trained. But which certainly align with the interests of agencies such as DARPA.
https://www.google.com/search?q=neurofeedback+enhanced+learning
http://www.americanboardofsportpsychology.org/portals/24/absp-journalhammond1.pdf
see list of papers at bottom of page
https://senselabs.com/science/
Leslie Sherlin is CSO with both SenseLabs and Versus
Sherlin intro and Versus demo, see protocols at 13:40 :
