Accelerometer Sampling Rate
Does the accelerometer have the same sampling rate as the EMG signal readings? If I'm using the wifi shield does that change the frequency for both or just the EMG?
also, is it just an accelerometer or also a gyroscope?
See this related thread, found with the "Google Advanced Search" button in upper right column. Try it yourself on some queries.
https://openbci.com/forum/index.php?p=/discussion/2294/change-accelerometer-sample-rate
https://www.google.com/search?as_q=accelerometer+sample+rate&as_sitesearch=openbci.com
The accelerometer is only a 3 axis. Does not have gyro capability.
