event synchronization between OpenSesame and OpenBCI?
ArnoArno Montréal
edited August 2020 in Software
I want to synchronize my Open Sesame events to the OpenBCI EEG headset. The EEG goes through a USB port and not a parallel port. Thank you in advance.
    Arno, hi.
    Cyton has 3 'Aux' channel inputs that can be used as 'external triggers' or event inputs.
    https://docs.openbci.com/docs/02Cyton/CytonExternal
    What types of OpenSesame 'events' are you working with?
    Some experimental lab frameworks also have historically used PC parallel ports, because these existed on old PC platforms. However NO current PCs offer built in hardware PC ports. On the other hand, various types of external parallel interface ports are available, both as usb port dongles, and as actual PCI cards,
    https://www.google.com/search?q=pc+parallel+port+card
    https://www.google.com/search?q=pc+parallel+port+usb
    All such interfaces will likely add a small amount of delay before the data appears at the PC app. With the usb delay being larger than the card delay.
    The previous link I gave for external trigger on Cyton, however, will precisely correlate with the EEG being sampled at that time. Since the 3 Aux channels are sampled at the same moment in time as the EEG.
