Hi William:
Is there any reason a BDF File can not be played back ? I get the message Playback does not contain the desired header data.
Recorded using OpenBCI_GUI 5.0
I was able to read the file with EDFbrowser without any conversion. So I assume the recorded file is OK.
AH. Understood. It is fine for me. BTW, I runned a very basic test at the Hospital last Friday. We took an EEG on a patient using bipolar montage 5 electrodes each hemisphere. I finally used my WiFi shield version and the OpenBCI_GUI V.5 running on Mac- Post analysis using EDFBrowser.
Results: Outstanding.
Hi William. LSL tested OK!
I just downloaded the GUI 5.0 source code to play a little bit with Processing IDE.
This are my first attempt to run the GUI from inside the Processing environment.
I want to set the DEFAULT configuration for Cyton with NO-BIAS, SRB1 and SRB2 "OFF".
Only Channels "ON", 24X Gain, and NORMAL inputs.
Hi William:
@nejemia GUI v4 CSV files will need to be converted to work with GUI v5.
The GUI will only play back CSV files, BDF files are best used with EDFbrowser or some other software.
Hope this helps! Take Care!
Hi Folks.
Does the GUI version 5 supports streaming LSL ?
Yes v5 still supports LSL streaming.
Make sure to move all of the libraries to something like
Documents/Processing/libraries[on Mac].https://docs.openbci.com/docs/06Software/01-OpenBCISoftware/GUIDocs#running-the-openbci-gui-from-the-processing-ide
