Cyton firmware update problem [resolved]
MarcusMarcus Washington State University
edited April 2020 in Cyton
I am having a problem with my cyton board after a firmware update. The channels are now offset.
I have an older cyton board (~5 years).
The markings on the board identify it as "V3-32".
It was working fine with a version of OpenBCI_GUI installed last June (2019).
A new team in our lab wanted to work with it and were not able to get it to connect to the latest version of OpenBCI_GUI. The readme said that the firmware was not compatible so I updated the firmware with the latest version available.
The cyton will now connect to the latest OpenBCI_GUI but the channels are offset.
Channel 1 data stream in OpenBCI_GUI shows a steady pulsing pattern.
Channel 1 wire signal (N1P) shows up on Channel 2 data stream, wire 2 (N2P) on ch 3, up to wire 7(N7P) on ch8 and wire 8 (N8P)) signal is not visible anywhere.
I have not changed the wires, they are in the same positions they have always been and I have verified that they are connected with N1P going to left frontal lobe, N2P, right frontal, N3P left parietal, N4P right parietal, N5P left temporal, N6P right temporal, N7P left occipital, N8P, right occipital.
I have tried to re-upload the firmware two more times and have rebooted my computer twice and still get the same results.
I used Arduino 1.8.10 to upload the firmware.
I followed the instructions from here:
https://docs.openbci.com/docs/02Cyton/CytonProgram#install-chipkit-core-firmware
