Cyton Impedance Output differs from Ganglion and Checktrode values
I’m having trouble with my Cyton’s impedance output.
Im trying to record/save impedance values across 4 channels simultaneously, but the values (real-time GUI output included) are not matching up with other tools I’m using to verify my data. I’m using a Checktrode model 1089 MK III and the ganglion to check impedance values and seeing completely different outputs on the cyton.
Hoping to continue utilizing cyton or its multi-channel capabilities, but have not been able to trust it thus far.
What electrodes are you using? Are your reference, ground connections the same in both setups? Does Ganglion match your Checktrode?
