Raw data sequence numbers, millivolt range samples
edited December 2014 in Software
Hi, I'm looking at the raw data files and have a question. I expected to see time stamps or sequential numbering but I see the following with the left column being repeat time over and over.  Its this data not time based but instead represents sequential snapshot of 30 frequencies every 1/250 of a second? If not, what do these negative integers represent?  I'm trying to plot this in excel to do some analysis and charting.
%OpenBCI Raw EEG Data % %Sample Rate = 250.0 Hz %First Column = SampleIndex %Other Columns = EEG data in microvolts
-29, 8081.03, -865.44, 19319.28, 31468.30, 4714.09, 36761.35, -587.38, 26779.51
-28, 7641.59, -845.37, 18335.31, 29751.33, 4410.33, 34759.82, -586.38, 25320.54
-27, 11011.34, -1218.13, 26441.22, 42836.22, 6349.84, 50050.63, -838.01, 36456.92
-26, 11253.32, -1239.29, 27008.26, 43812.66, 6513.92, 51190.20, -847.11, 37284.79
-25, 8650.79, -943.85, 20747.91, 33684.50, 5021.52, 39353.35, -641.34, 28665.91
-24, 7839.11, -858.66, 18819.74, 30543.50, 4541.02, 35679.64, -587.60, 25991.48
-23, 9083.59, -988.33, 21808.86, 35371.27, 5258.18, 41330.65, -674.69, 30106.37
-22, 9370.79, -1021.45, 22475.91, 36478.40, 5420.41, 42621.87, -699.86, 31046.37
-21, 8285.79, -904.84, 19865.83, 32214.38, 4782.71, 37647.51, -621.60, 27421.97
-20, 7669.91, -839.35, 18382.90, 29819.39, 4430.27, 34849.56, -573.88, 25382.28
-19, 7913.70, -873.89, 18990.96, 30806.51, 4576.32, 36001.14, -589.77, 26218.50
-18, 7970.50, -873.06, 19110.25, 31023.08, 4608.30, 36247.33, -596.34, 26399.82
-17, 7534.79, -829.74, 18101.85, 29343.43, 4341.69, 34289.47, -572.54, 24970.43
-16, 7067.73, -779.76, 16950.02, 27509.54, 4085.27, 32144.98, -534.47, 23408.91
-15, 6720.05, -744.63, 16135.54, 26167.65, 3879.57, 30575.26, -508.90, 22270.78
-14, 6573.11, -718.56, 15760.03, 25569.88, 3804.15, 29875.92, -488.54, 21763.80
-13, 6354.24, -697.91, 15231.15, 24721.16, 3670.22, 28886.25, -478.80, 21041.08
-12, 6094.00, -660.34, 14592.02, 23707.84, 3529.72, 27698.05, -451.57, 20178.93
-11, 5942.61, -658.82, 14268.30, 23129.65, 3429.47, 27033.92, -450.92, 19693.38
-10, 5895.92, -637.14, 14126.64, 22906.45, 3399.97, 26767.42, -442.90, 19495.70
-9, 5690.13, -619.81, 13647.84, 22128.83, 3282.73, 25862.98, -432.44, 18841.65
-8, 5397.81, -581.77, 12929.97, 20992.73, 3125.47, 24533.52, -406.00, 17870.22
-7, 5238.02, -580.68, 12572.52, 20387.65, 3022.58, 23823.58, -404.10, 17351.32
-6, 5049.71, -570.26, 12130.45, 19676.98, 2920.08, 22988.65, -384.58, 16741.30
-5, 4790.45, -521.67, 11467.76, 18610.87, 2772.38, 21739.91, -355.71, 15830.26
-4, 4611.03, -507.74, 11054.19, 17935.57, 2661.62, 20955.25, -352.49, 15258.26
-3, 4572.52, -496.63, 10968.67, 17785.75, 2636.48, 20777.11, -352.38, 15126.72
-2, 4449.96, -484.76, 10687.80, 17343.10, 2570.50, 20260.56, -343.50, 14752.26
-1, 4205.75, -465.65, 10115.62, 16417.35, 2436.12, 19175.96, -322.87, 13964.38
0, 4023.65, -449.52, 9686.17, 15717.07, 2335.71, 18357.08, -308.95, 13369.87
    Davy, the first column is just a sequence number that normally increases by one on each sample time (250 of them per second). This is a one byte integer that "wraps around". If by a very rare chance a number is skipped, it means that sample was lost. It is in effect, the "time stamp" you are looking for.
    As far as the large positive or negative microvolt values, see,
    http://openbci.com/forum/index.php?p=/discussion/201/large-millivolt-data-values-dc-offset
    Note that on that post the author shows a modified CSV file with a millisecond timer as the first column. He changed the source to do that. (Just to see how consistent the clock values were at reception time. Which as expected are nominally [1/250 =] 4 milliseconds apart.)
  • edited December 2014
    oh ok! Great, I'll just replace the column with a sequence then.
    Davy,
    It looks like the sample counter is getting interpreted as 2's compliment. It is a byte, and it should count from 0 to 255, then roll over to 0 again...
