Problem starting OpenBCI_GUI in Ubuntu 18.10
in OpenBCI_GUI
I've got a problem that I need help
figuring out a solution to. Whenever I start OpenBCI_GUI in Ubuntu 18.10
I get connection exception, see below. In the team we have seen it on 2
computers of different brands, and haven't been able to solve it for
any of them.
any of them.
What is working:
- The Gui starts, and shows the Data source menu.
- When selecting Synthetic everything looks good, and I get data in the selected amount of channels
What isn't working as expected:
When I select Data source "LIVE (from Ganglion)" I expect a menu to
choose either wifi or bluetooth, the menu doesn't show up. If I try to
start the system nothing happens, neither in the gui nor in the logs.
- When I start OpenBCI_GUI I get logs about ConnectionException, the full log is included below.
What have been tested:
- Start with and without USB dongle
- Start as sudo and without sudo
- 2 computers from different manufacturers
Changing to windows on one of the computers worked. However the other
one doesn't have windows, and it haven't been tried on the other
computer
computer
Can you please help me figure out what I'm doing wrong?
sudo ./OpenBCI_GUI
[sudo] password for krister:
Screen Resolution: 1920 X 1080
For more information about how to work with this code base, please visit: http://docs.openbci.com/OpenBCI Software/
Local Version: 410, Latest Version: 410
GUI is up to date!
Graphics & GUI Library: ControlP5 2.2.6 infos, comments, questions at http://www.sojamo.de/libraries/controlP5
The
file "SavedData/Settings/UserPlaybackHistory.json" is missing or
inaccessible, make sure the URL is valid or that the file has been added
to your sketch and is readable.
attempting to load images for presentation...
DONE loading images!
java.net.ConnectException: Connection refused (Connection refused)
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350)
at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206)
at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
at java.net.Socket.connect(Socket.java:589)
at java.net.Socket.connect(Socket.java:538)
at java.net.Socket.<init>(Socket.java:434)
at java.net.Socket.<init>(Socket.java:211)
at processing.net.Client.<init>(Unknown Source)
at OpenBCI_GUI$Hub.startTCPClient(OpenBCI_GUI.java:13223)
at OpenBCI_GUI$Hub.<init>(OpenBCI_GUI.java:13199)
at OpenBCI_GUI.systemUpdate(OpenBCI_GUI.java:1213)
at OpenBCI_GUI.draw(OpenBCI_GUI.java:605)
at processing.core.PApplet.handleDraw(PApplet.java:2429)
at processing.opengl.PSurfaceJOGL$DrawListener.display(PSurfaceJOGL.java:866)
at com.jogamp.newt.opengl.GLWindow.display(GLWindow.java:759)
at com.jogamp.opengl.util.AnimatorBase.display(AnimatorBase.java:452)
Instantiating hub object...
GUI is up to date!
The
dongle it is, but I can't manage to figure it out. But I don't think
it's relevant, I don't get far enough in OpenBCI_GUI to be able to
choose how to connect.
also tried to install a virtualbox image with Ubuntu 16.04, when using
that I can open the OpenBCI_GUI and get the menu to choose how I want to
connect to the Ganglion.
