getting started, dongle drivers
so, first off i should be clear that i know very little and virtually nothing about eeg at this point. any general/introductory resources would be great if anyone can point me in the right direction.
i'm trying to boot up my equipment but i keep getting an initialization failure in the gui. both blue lights are on, but they're not connecting
i've got the 32-bit chip, anyone else having this trouble or am i doing something wrong here?
Mac OS X 10.9.5 is Mavericks. Please follow the directions at this link, (as suggested previously when I mentioned searching on 'vcp'),
http://openbci.com/forum/index.php?p=/discussion/196/os-x-and-virtual-com-ports-mavericks-yosemite-note/p1
Which OS are you preferring to use? On Windows, the driver is automatically installed once the dongle is inserted. Did you allow it to do the automatic install from Microsoft? If the auto install had problems (unlikely), then you can do a manual install from the FTDI VCP page,
http://www.ftdichip.com/Drivers/VCP.htm
If you use their installer, please uninstall any previous drivers first.
I assume your dongle switch is NOT on 'Reset'. You say "it's asking for drivers" but then "showing up as FT231X...", which implies the auto install worked. Are you specifying THAT particular COMx port in the Processing GUI startup? You have to match the serial port with what you have installed.
I'm also having problems with the dongle and the software. Any help would be appreciated.
When I plug the dongle in, nothing happens, I don't even get a light on the dongle. I'm using a laptop with windows 7 on it which is supposed to recognize it when you plug it in but it does nothing. I have the 8-bit card. I've checked the device manager and can find nothing there either for the dongle. I have 3 USB ports on my computer and I've tried it in all 3, but nothing happens. I also checked to make sure the dongle was set to GPIO_6 instead of reset.
When I turn the 8-bit card to PC it quickly flashes a blue light which then goes out so I'm assuming it's working.
I tried to run the software as well but when I try to run the OpenBCI GUI inside Processing I receive this error:
Framebuffer error (unknown error), rendering will probably not work as expected Read http://wiki.processing.org/w/OpenGL_Issues for help.
OpenGL error 1286 at bot beginDraw(): invalid framebuffer operation
ControlP5 2.2.2 infos, comments, questions at http://www.sojamo.de/libraries/controlP5
RESIZED
OpenGL error 1286 at top endDraw(): invalid framebuffer operation
RESIZED
and the OpenBCI_GUI window comes up blank. I have copied the "controlP5" and "gwoptics" folders into Processing/libraries inside my documents folders as per the instructions so I don't think that is the problem. Could the error be because my computer isn't recognizing the dongle?
Thanks for any help you can provide.
I updated the drivers for my graphics card and that seemed to get the
OpenBCI_GUI to work. I at least got to the menu on it where I could open
a file or playback a file although I have no files to playback yet. I
have also made sure windows was updated.
Now all I have to do is
get the dongle working. The computer still does not recognize it at all
and there is no light on it. When I bring up the device manager all that
is there is under "Other Devices" it says "Unknown device" I've tried
to get windows to install the drivers and it comes up with "device not
found" I went to the website above to download the drivers and
downloaded the one for Windows version 2.12.00 WHQL Certified. It is an
exe file and when I tried to update drivers and browse for drivers it
wouldn't find the file so I clicked on it to install since it's an exe
and that didn't work either. Maybe I downloaded the wrong driver? Any
other suggestions?
I'm not even sure if the unknown device is the
dongle because it still lists an unknown device even when I don't have
the dongle plugged in.
My computer info is as follows:
Manufacturer: ASUS
Model: U56E
Intel(R) Core(TM) i5-2410M CPU @ 2.30Ghz
6GB RAM
64-bit operating system
Windows 7 Home Premium Service Pack 1
Graphics card - Intel(R) HD Graphics 3000
I plugged the dongle in on another laptop and it didn't register anything either, although the laptop was also an asus. I also tried plugging it into an old XP machine but even doing a search for new hardware couldn't find it.
Thanks Paul, I checked it and it's not upside down.
